I-max 99 vs I-max 2000
hotmetal1000
I've been doing a fair bit of looking around at different antenna and what's easly available here in Aus. From what I can gather the I-max 99 is very simaliar to the Antron 99? Does anybody on here have much experience with the I-max 2000? All antennas are made by Solarcon of course.
Cheers guys,
Jeff.
IMAX 2000 is a very good antenna but seems to be a bit fragile
hotmetal1000
Well my I-max 2000 and ground plane kit arrived today, was like a child getting a Christmas present unpacking it. I haven't got it up yet, need to get some steel to make my mast with but I did assemble it inside me shed on the floor. Wow :shock: it is big, I had forgotten how big a 1/2 wave antenna was and this thing is a 5/8th wave. Over 7 metres of it. :shock: :shock:
long shed then
:D :D :D :D :D :D :D :D :D
hotmetal1000
Well I finished setting up my I-max 2000 this afternoon. It's mounted on a pole bolted to the side of my shed with the bottom of the 2000 6m above the shed roof. Total distance from the ground 10m. Before I disconnected my old antenna I put out a call but couldn't hear anything much happening. Plugged in the 2000 put out a call and immediatly got 3 returns and started dx to parts of South Australia (1500km) and got a contact in New Zealand. I am totally amazed at the difference the I-max 2000 has made. Couple of pics for you guys.
looks good
:D :D :D :D :D
EarthWormJim
very nice mate 8)
Jim,
2H4OW
M3OJP
very nice mate i bet your proud as punch i wish i had the room for a i.max but i will have to do with my antron 99????????????
best wishs paul 26 f b 315 =D> :roll:
hotmetal1000
Thought I would update the pictures of me setup,
Imax-2000, Icom AH7000 and wire dipole for 14mhz
Uniden AX-144 CB and amp, Kenwood R-1000 receiver, Icom 718 HF tranceiver and Uniden hand scanner
hi ..jeff very nice setup love the antenna and i like how you have the scanner antenna also on the same pole
realy like the shack ive been looking at the galaxy base mike to go with my 95t2 but must save my pennys first but with xmas comeing my wife might
have a moan... [-o<
best wishs porky paul :)
hotmetal1000
Hi Porky Paul, the galaxy base mike is definantly a good thing. I was told with the standard mike on the uniden I was very soft, now with the base mike set properly so as not to over drive the radio I have gone from soft to loud and can stomp right over the top of other breakers and make contacts in the traffic jam when the skip is running.
yes very nice they seem good base mikes and the eco settings sound nice on them.. *King*
