Best CB Radio for Europe Trip?
- andy@thunderpole.co.uk
- Site Admin
Sorry the description is a bit misleading.
They would both be suitable as they both use the same chassis and are the same dimensions.
Ok a bit of a stupid question... if I were to get two smaller arials, would I get the same range (transmitting and receiving) as one very long one?
does anyone have any recommendations on arials that are a little aesthetically pleasing too?
Ok this one don't look too bad: http://www.thunderpole.co.uk/on-glass.htm
There must be a way of getting several of these and connecting them together to get a better range?
- Site Admin
You will be lucky to get any more than about two miles out of that antenna.
You cannot connect more than 1 antenna to get a better range, unfortunately it doesnt work like that
The only way to get a good range (more than 5 miles) using CB is to use a decent size antenna...
Hey Stampman.. it says that is almost a metre high!! Thats too high man... way too high...
Any other suggestions? I think I'm just gonna go for the internal window antenna.. unless there are any discreet external ones. Trouble is, I know the internal window one will suck!
Need atleast 5 miles trans/recv range.
you know more than me never heard of a window antenna you cant have a discrete antenna unless you go for an antenna specialist aerial and have not seen one of those for about 20 years but rest assured we can repair the set when you blow it up why discrete any way your not a james bond type are you
wilson 1000 will stick on at 140mph and don't ask me how i know
