Best CB Radio for Europe Trip?
sab
Another thing I just thought of. If I mount the unit in my dash then how am I going to get the wire of the mic to come to the front? I assume that you plug the microphone into the back of the unt?
sab
Hey Andy,
Would it be the same if I mounted a 150 or a m760? The listing says the 150 is 'ideal' for it? What makes it better?
sab
sorry no i meant about mounting it in the din slot. Should be the same for both right? as they have the same dimensions?
Sorry the description is a bit misleading.
They would both be suitable as they both use the same chassis and are the same dimensions.
sab
Ok a bit of a stupid question... if I were to get two smaller arials, would I get the same range (transmitting and receiving) as one very long one?
does anyone have any recommendations on arials that are a little aesthetically pleasing too?
no they would not work better dont go for looks go for performance it would be like having a farri withe a scoda engine in it
sab
Ok let me rephrase...
Can I get a small arial with the same performance as a longer one? Like maybe a coiley one or something? :?
I'm going to mount it on the boot... but am scared if it is too long... it may come off at 170mph... :lol:
sab
Ok this one don't look too bad: http://www.thunderpole.co.uk/on-glass.htm
There must be a way of getting several of these and connecting them together to get a better range?
You will be lucky to get any more than about two miles out of that antenna.
You cannot connect more than 1 antenna to get a better range, unfortunately it doesnt work like that :(
The only way to get a good range (more than 5 miles) using CB is to use a decent size antenna...
sab
Hey Andy,
Can you recommend a couple of decent looking antenna's so I can decide on my perfect setup. It can't be too tall due to the high speeds and aesthetic reasons...
wilson little will but if you whant the performance then the 1000 will do the job
sab
Hey Stampman.. it says that is almost a metre high!! Thats too high man... way too high... :(
Any other suggestions? I think I'm just gonna go for the internal window antenna.. unless there are any discreet external ones. Trouble is, I know the internal window one will suck! :(
Need atleast 5 miles trans/recv range.
you know more than me never heard of a window antenna you cant have a discrete antenna unless you go for an antenna specialist aerial and have not seen one of those for about 20 years but rest assured we can repair the set when you blow it up why discrete any way your not a james bond type are you
wilson 1000 will stick on at 140mph and don't ask me how i know
thunderpole atom small and very good on receve... :wink:
sab
Porky, you mean this one? http://www.thunderpole.co.uk/atom.htm
It's 1 metre high! :shock:
