pl259
padster
CB Handle: night owl
well my dv 27 arrived i mounted it on a steel plate and put that on biscuit tin but no pl259 in box thunderpole sending me one out any advice how to connect it please
FISH
Theres a how to fit a pl259 plug in the tech section.
26 TANGO MIKE 501
yes mate andys right theres a very good tread on hear about this
its easy enough just dont burn your fingers lol :D
padster wrote:well my dv 27 arrived i mounted it on a steel plate and put that on biscuit tin but no pl259 in box thunderpole sending me one out any advice how to connect it please
LOOK UNDER TECHNICAL HELP
FISH
HOT,HOT,HOT. :lol: :lol: :lol:
26 TANGO MIKE 501
yeh just make sure the bradle is in contact as if its not u will get a bad earth
padster
porky.69 wrote:yes mate andys right theres a very good tread on hear about this
porky i think sussed it put a load of silver foil down and swr has come down i got readings channnel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok please reply [-o< [-o< [-o< [-o<
disgwylfa
CB Handle: 186-TM-555
padster wrote: i got readings channnel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok please reply
The 2.4 is a bit borderline but "anything under three" is usually considered unlikely to damage a radio. I try adjusting the tip of that DV27 slightly, shorten it about 2mm and check Ch.1 and Ch.40 again.
If you can get under two on all channels, that'll do you.
Steve ("Cherokee")
padster
Steve ("Cherokee")
thanks very much :mrgreen: :mrgreen:
padster
Steve ("Cherokee")
i got readings channel 1 1.6 channel 20 o.1 and channel 40 1.7 is this ok
disgwylfa
padster wrote: i got readings channel 1 1.6 channel 20 o.1 and channel 40 1.7 is this ok
That'll do you nicely. Go do some talking :)
Steve ("Cherokee")
nice one mate :wink:
nice one mate
