25 Watts or 150 Watts
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
and if it is not you can 1)buy a bigger one to run both at once 2) buy a smaller one that will just run the amp so you will have one on for the radio one on for the amp
- Photographer
- Official CB Nut
- CB Handle: Terminator / 26TM233
- Contact:
Ah, didn't think of that, 2 psu's??
I have got a Watson Mite NF with 20A output, 23A max so I reckon it should be OK for the Ranger 2950 and the 100W amplifier?
Anybody know any different and I'll pick up another smaller PSU.
Cheers guys!!
Cheers guys!!
http://www.stphotography.org
- killer cam
that sounds ok to me but for example if the lights on the radio go dimer when you tx you need a bigger psu sure you wont tho and make sure you have a very low swr because amps increase your reflection on your antenna so make sure its about 1.9 at the most
- Photographer
- Official CB Nut
- Contact:
Should I get one of these to be on the safe side, are they any good?
Zetagi TM999 Matchbox - £50 at Thunderpole
- Photographer
- Official CB Nut
- Contact:
The Matchbox is a combined SWR Meter and Matcher, was wondering if that will help keep the SWR low (below 1.5)?
- Photographer
- Official CB Nut
- Contact:
What's wrong with Switch Mode PSU's??FISH wrote:try not to buy a switch mode psu.
northern35s
EMI, electromagnetic interference, created by the switching relays, the noise could be the difference between making the DX or not, especially when conditions are marginalPhotographer wrote: What's wrong with Switch Mode PSU's??
- killer cam
stampman wrote:no swr the antenna properly as all the matcher does is fool the swr side and loses power
northern35s wrote:EMI, electromagnetic interference, created by the switching relays, the noise could be the difference between making the DX or not, especially when conditions are marginalPhotographer wrote: What's wrong with Switch Mode PSU's??
- killer cam
