Microphone problem i really need some help
Bulldoguk
Hi Guys
Like the tittle says i am having real problems trying to wire up a microphone to a harrier cbx and i really hope someone can help me out.
Ive tried a couple of diagrams and had no luck including the one on this site and im about ready to get a hammer out :cry: http://www.thunderpole.co.uk/mic_wiring.htm
It is a (other company) microphone CM-500U i bought it from maplins http://www.maplin.co.uk/Module.aspx?Mod ... Code=A37GJ
Everything i have tried has not worked on the diagram on this site i get sound but it wont key up and when i do press the ptt button the sound goes but im sure the needle is still responding to the skip on the channel (hope that makes sence)
Strange thing is i get sound and if i pop a metal object across pins 1 and 3 the radio keys up and the metre and swr metre respond.
The colours on the microphone wire are yellow shield black and red if it helps i can put the colors of the wires inside the case and take a picture.
Hope you guys can help many thanks Mike
it is a condenser mic which wont work on the older set's ie harrier rotel york will switch between tx and rx but wont tx audio
Bulldoguk
Dam cheers for that i think i have alot to get used to with all the changes :( could you recommend any and link them as we dont have any cb shops in my area anymore.
Sorry for the late reply ive been on a 14 hour shift today but whilst i was at work my Jesan CB-950 40 channel hand held arrived old i know but i love it and a bargin at £11 :) told the missus i got it for my son so he can talk to me SHHHHHHHHH :)
phone colin at our sponsers and if he anit fishing he should sort you out
