Supressers
stewartyboy01824
People talk about supressers for the alternator all the time, What are these because ive never been able to find one or anything about them on the net. Are they an old fasioned thing??
This is the original old style fix for removing alternator whine from radios or CB s . Attatch it to alternator wire and clamp to earth.
http://www.rimmerbros.co.uk/Item--i-579 ... edium=feed
12v line noise filter .
http://www.thunderpole.co.uk/cb_accessories_misc.htm
http://www.rdm-entertainments.co.uk/pro ... prod=B070D
Not old fashioned at all, have a read on a few ICE forums, the noise problems that can affect CB equally apply to modern in car AV and stereo.
Those suppressors are actually whats known as a "capacitor" in electronics circles and "condensors" on car ignition systems, but when applied correctly they effectively kill all noise.
modern car electrical systems have built in suppression as standard ,Problems appear when using poorly shilded high amplification systems or faulty engine earthing straps. Modern computerised ABS cars may give interference at certain lower freqencys .
Dragonfly wrote:modern car electrical systems have built in suppression as standard ,Problems appear when using poorly shilded high amplification systems or faulty engine earthing straps. Modern computerised ABS cars may give interference at certain lower freqencys .
On that note, OP, assuming it's a negative earth vehicle, connect a jump lead to the block and take it to a known good earth point on the chassis and see if it gets better...
