Hiya,
I'm just getting around to kicking off on this CB lark and I'm curious to know which (non-mag) aerial is going to best suit the following vehicles
1995 106D (old stalwart of the "fleet" 176K miles!)
2001 Berlingo 800D van twin 180 degree "barn" doors on rear
2003 Transit (this would be easy to fit to, roof rack 'n' all but meh...)
Now, the problems are as follows
1) No gutters on either of the first two vehicles
2) No roof rack to cheekily clamp on to on first two
3)needs to hopefully be easily transferrable.
4) I'm a car paint perv.. I spend hours washing cars and am worried that a mag base aerial would damage the surface it's stuck to..
any thoughts/comments/suggestions welcome
Phil
Antennae assistance
stampman wrote:will cause sun fade eventualy
Car is a 176,000 mile pug - doubt it will be round long enough for that to happen! Besides, provided it's moved fairly regularly, I don't think that would be a problem with a mag base. The works van wouldn't matter as you can't see the roof and if it did fade, in either case, i can just buff it up again with no more said
At the moment, I *think* I'm leaning toward a booted mag base as despite my misgivings, if there is no direct contact between the paint and magnet, then I don't think too much damage will occur unless I put it on a dirty panel. it seems to match what I'm after best (i.e easily moveable and secure in one). Then, if I get "into" this lark, I can do a more permanent installation on them with holes etc getting involved
Regards
Phil
well, i bought a T1000 starter kit with mag aerial base and MIni orbitor. Owing to it being a works van, and having 2 other random antennae as well as the radio aerial, i thought a full whip might be a bit too much. I might yet change my mind and purchase another whip though.
Yesterday evening, I broke down outside a well known electronics outlet and whilst waiting for the RAC man, purchased a SWR meter as well as patch lead.
Upon testing the above, i had an SWR of 1.5 on 1 and 20 with 2 on 40. PRetty fair considering i've done nothing bar slap it on the van roof....
