Hello there again,
Not been on for a while and I am wondering if anybody has come across this problem on the Midland 42.
Squelch - open all the time.
With the set opened up - the 10k squelch pot measures min to half way 0 to 1.25Kohm and from half way to max 1.25k to zero.
It is difficult to visualise how the pot itself has developed this fault - so - it must be something else.
Hope someone can give me some advise.
Thanks and regards
Bob Davies
Midland 42 squeslch problem
Found this site useful before, there's a section on repairs. Don't know if it'll help but worth a try
http://www.m0ysu.com/
Currently running: Amstrad CB901 with Mk1 Road Runner
- Off Roader
- CB Handle: Off Roader
Bob22,
Quite difficult to measure the pot (or any other component) when it's still in circuit which could explain your low readings. Disconnect it from circuit and measure it again. Pots very rarely loose their value, normally just get "scratchy" with age which a good clean with switch cleaner will sort out.
Dave, aka Off Roader (aka Hero from the 80's)
Dave
AKA Off Roader
AKA Off Roader
