dont mean to be dumb..lol
hi all, i dont mean to be dumb or ask a silly question but i dont underdstand so thought i would ask... i have only had a cb for a few months and been using a mag mount in the roof, i want to use my cb now in my house and not having much luck with getting a low SWR on metal things in the home, lol so looking at getting a ourdoor antenna but not sure which to go for, looking not to bad and cheap
and i dont understand how a outdoor antenna doesnt need a groundplane but a car antenna does :S any help would be great so i can learn more and understand how it all works, thanks.. james
ok thanks, with any antenna outside do i need to use a steel pole or isit just advised to give better signal? if i just bolted an antenna to the side of the house and ran the coax cable to the ground incase of lightening would that work ok? thanks
- andy@thunderpole.co.uk
- Site Admin
- Contact:
20 quid seems expensive.
We have all the fittings here... http://www.thunderpole.co.uk/base_stati ... sories.htm
thanks, jst had a look at the link and thats better prices
lolso could i just both the t&k brackets to the side of the house and fix the antenna to the bracket or do i need to use a pole from the bracket and then fix the antenna to the pole thanks?
- Site Admin
- Contact:
You need to use a pole. The pole clamps to the T&K's using U bolts, then the antenna clamps to the pole.
- Site Admin
- Contact:
All the homebase antennas we sell come with brackets to attach them to a pole.
