Basic info required please
gold735uk
Hi everyone and thanks for having me onboard, i have just purchased an old 40 channel rig off the bay of fleas, when i cue the mic the needle on the signal meter goes up and bounces straight back down, even though the mic is still cued, is this how it should react ? The rig is badged up as a Barracuda but not the common well recommended black fronted one, i cant find any info on google about it so thought i would ask here. The mic is brand new as the one that came with it had loose connections.
Many thanks
Cliff
Guzzy
CB Handle: Guzzy
Does it look like this one:
or this one:
gold735uk
Nope, neither, it has the big channel select button on the right with barracuda beneath, hi/Lo switch on rear, power meter on left, pa/cb switch, dials for vol, squelch, rf gain and dimmer from left to right and that's all so nothing like the barracuda I've seen lots of. It's the behaviour of the meter when I cue that concerns me because I don't think its transmitting which leads me to believe I've been sold a lemon.
gold735uk
So wish i had spent my dosh more wisely on a proper barracuda or magnum deltaforce/omegaforce/257, the unit has a red LED readout for channel indicator by the way.
Guzzy
CB Handle: Guzzy
Post a picture of it.
What mode are you operating in?
When you TX, are you speaking (driving audio) into the mic?
It will be late 70s Barracuda GT868 radio built by the chinese.
Same board is fitted to these CB Radios----
Commtel GT868-------------------------------Commtel GT858
Barracuda GT868------------------------------Commtel 40
Sapphire X2000-------------------------------cheiza 701
Lake Manxman 950---------------------------Lake Manxman 850
Transcom GBX2000--------------------------- Elftone EL-CB 6000
Academy CB502-------------------------------Academy CB501
Gecol GT868-----------------------------------Gecol GT858 B
Sumeet GT858-------------------------------Tokai GT858
SonicGT868---------------------------------Eurosonic GT858 & Euro 11
Fidelity 1000fm
mic wiring - http://highfields-arc.co.uk/constructor ... cuda02.htm
SVR1 = Recieve needle adjust
SVR2 = Squelch adjust
SVR3 = Mic gain adjust
SVR4 = Key up needle adjust
gold735uk
Thats the Fella thanks Dragonfly, i dont particularly want to open and start messing to be honest.
Guzzy, i was just keying the mic, no traffic, i take it when i talk it should move the needle ??
Many thanks for taking the time to reply both *King*
Cliff
gold735uk
Further to your question guzzy it reacts the same regardless of whether I am talking or not.
Guzzy
CB Handle: Guzzy
Sounds like it's in need of a visit to a rig doc.
To be fair, it is 30+ years old.
post us a picture of the Barracuda and your antenna.
These radios are usually fairly robust and long lasting as they dont usually get much use before people buy a better radio,Having sead that given the right antenna they can get out well enough,they were prone to bleadover from other users but can be handy these days to tell you that mobile breakers are passing by on another channell.
gold735uk
Dragonfly, the rig is exactly as your picture apart from it has barracuda badging. The antennae has a tight spring on the base, then thin, then a black cylinder then thin to the tip. I cant add pics from my mobile :(
Where will I find a rig doctor and is it worth it, I'm in Tamworth in Staffs.
Many thanks for your continued help.
Sounds like u have the small mobile Antenna
Heres mine and she works a treat.
gold735uk
If you have an email address I can send a pic or to a mobile, my mail is instructorbadger@hotmail.com
Many thanks,
Cliff
tamworth nip down to see andy at thunderpole and he will sort it
gold735uk
Where will I find Andy then please. I'm not home until Fri afternoon/evening now though
