Better antenna
UnderCover Runner
CB Handle: UnderCover Runner
Got a Cobra 19DX IV EU of ebay a while back and it came with a SWR Antenna. Only can get 2 mile range if that.
What would be the best antenna to get for a small car (Seat Ibiza) rather have a mag mount the start drilling holes in the roof!
Thanks in advance
Dom
Work, Sleep, Work, Sleep, Work, Sleep, Day off, lounge around, Sleep, work, sleep.
hi dom, i use the sirio 4000 but there a large antenna, take a look at the antenna section on the thunderpole shop ......i also like the red thunder antenna *King*
Guzzy
CB Handle: Guzzy
Unfortunately, if you want decent range, you have to go for a longer antenna.
Look on the bright side, if you choose one that is less than 9ft (2.74m), you are running an antenna that is actually smaller than it 'wants' to be.
There you go. Those 5.5ft (1.6m) antennas don't look so bad now, do they!? :lol:
UnderCover Runner
Just had a proper look. Thinking of the Orbiter HD Centre load.
Guzzy
CB Handle: Guzzy
I've got a few different antennas, but the one I run most often is the TZ27. It's cheap and cheerful and for a long(ish) antenna it's surprisingly discreet due to the small loading coil.
It works OK for me.
I run a Les Wallen Modulator (Voyager) if I mean 'business'. :lol:
wilson 1000 is a super antenna
UnderCover Runner
Cheers guys! :D :D :D
stampman wrote:wilson 1000 is a super antenna
another very good antenna *King*
joe jeep
CB Handle: Joe-Jeep
I use a modulator now the voyager and have had some good results. What's the TZ27 like?
Joseph
Handle:Joe-Jeep
Guzzy
CB Handle: Guzzy
joe jeep wrote:I use a modulator now the voyager and have had some good results. What's the TZ27 like?
Joseph
It works just fine. I like it because the coil is relatively small and discrete and the whip kind of disappears at a distance.
The Modulator has a mahoosive loading coil that just screams CB RADIO!!! :lol:
Laurie
CB Handle: Whispering Thunder
I just wondered how different the Modulator was in comparison to the TP Red Devil?
I am aware that 1 is made in Kent and the other in Birmingham but wonder if there are any differences in performance?
Discuss
LulaNord
Hi...i am a new user here. i think if you want decent range, you have to go for a longer antenna.Look on the bright side, if you choose one that is less than 9ft (2.74m), you are running an antenna that is actually smaller than it 'wants' to be.
