Which cb?? Interference problems.
stewartyboy01824
Hi there i wonder if anyone can help. I am interested in buying the new 'midland 248 xl' and was just wondering if it has midlands new 'noise blanker' system as i have terrible interference in my new holland tractor. The new' midland 278' and some other new '200 series' midlands are described as having this new 'noise blanker' system but the '248xl' doesnt seem to have it. Is this a miss print or does it not have the new 'noise blanker' such as the 278. If not i may consider a 'lafayette trucker' with the front speaker and audio tone filter. Many thanks. Stewartyboy. P.S If anyone out there can recommend the best cb to purchase that has new filter technology for interference problems then please let me know. Thanks im 10 10 on the side.
stewartyboy01824
Thanks for your reply stampmam, i have tried various things to cure the problem. With the tractor having very complicated electrics, it is very difficult to find the source of the interference. The interference occurs when engine running or when putting foot on throttle, if im coasting down a hill or briefly when i take my foot off the trottle it is ok. Does this sound like the fuel pump? The interference doesnt come through as a signal but as a horrible noise overpowering anyone trying to speak to me. I was thinking for my new tractor arriving next march to buy a midland 248xl, an rfi noise clipper filter, a bumper power line filter and an external speaker with a noise filter to give me the best chance of having a clear reception again. Or am i wasting my time??? Should io just buy a normal cb and take my chances? many thanks for your replies people, all the advice is greatly appreciated as my cb is pretty unusable. Thanks. Stewartyboy.
if its a wine that goes up in pitch when you accelerate that could be the alternator check all earth connections and fit suppressors to the alternator and the fuel pump and try that
Are you running the CB radio DIRECTLY from the battery or is it going through a cig socket, voltage dropper, or some other improvised wiring setup?
You often find problems if you wire the radio into the vehicle wiring loom. If possible, wire it directly to the vehicle battery (assuming it's 12V?).
stewartyboy01824
Thanks for your reply guzzy, the cb is currently wired to red and black power power terminals on the the right hand side dash at the back, these terminals are in place for auxilary control boxes for implements etc or 'cb radios'. I have tryed wiring strait to the battery before and it has made no difference. Every cb shop i speak to for advice say they constantly have users complaining about new holland tractors.
If the Tractor is causing noise on CB channels that you are listing to, and it's only occurring when you are plugged into the power supply of the tractor - then it's coming through the electrical system.
Apart from talking to a qualified tractor electrician about it, I think you've already mentioned pretty much everything you can do (an rfi noise clipper filter, a bumper power line filter and an external speaker with a noise filter).
Sometimes it just takes a little trial and error to get it working right.
I have used a rubber boot on a mag mount before to reduce interference on problematic trucks , Modern computers and ABS systems have become a problem on some of the trucks that i drive .Often the Interference is only on certain channells but when its on 19 then the jobs knackard .
stewartyboy01824
yeah stampman the noise occurs when stationary with the engine on or when on the move using the throttle, its ok with the engine off and ignition on. the strange thing is when coasting down a hill (when theres no strain on the tractor) the noise becomes fainter and almost dissapears making it easier to hear the conversation. but once i start pulling up that hill on the other side its game over. strange! Could try another battery in the cab with me to see if its the power supply i supose.
Sounds like the fuel injectors - on modern systems, the fuel gets cut when the engine is on overrun, so there's no noise when going downhill
My van was the same - I could even hear the noise on the homebase radio when the van was ticking over outside. I managed to reduce the noise by fitting ferrite rings to the wires connected to the injectors. Clip-on ferrites were useless, but extending and winding the feed wires around the ring type ferrites helped quite a bit, but didn't cure it completely.
A common problem these days.
stewartyboy01824
Thanks for your advice stampman, will try that (if i can ever find the fuel injector wires)
