Telescopic masts
- Bionic Budgie
- CB Handle: Bionic Budgie
Hi Andy..
Think your talking about a Silver-rod type that sell for around a tenner, I have one of these 'cheapy' silver-rods and for what it is..its pretty good. I have the halfwave at 18 feet and this put on a twenty foot pole works very well. The antenna is VERY light and is easy to put up and adjust. The only downside is the quality. The antenna probably won't last. I now have an Imax 2000 fibreglass antenna and is fairly robust..BUT..its bloody heavy. The Silver-rod is so light you can hold it with one hand. My advice to you is to start with a silver-rod but buy the more expensive one as the ali quality will be better and it will last. Don't bother with the longer 5/8 wave one with the small and pointless ground plans..the half wave is just as good. Hope this helps. At home at the moment due to snow so monitoring the usual 28 and UHF 12.
TTFN
Ian
TTFN
Ian
I went for the "cheap" telescopic mast in the end, attached a j pole for 446 up top, and a tank whip for 11m on a mast attachment as well. The trade off for cheap is having to keep an eye on wind strength and lower antenna if wind is strong. Advantage... I got on the air on 11 and 446 on a budget, without spending stupid money initially. I'm sure as the hobby takes a hold, takes over my life and punishes my credit card things will change. But I am in control.... For now!!!
