Burners
Johnny Mac
Is it ok to use a burner on a mobile set up in a lorry?
no you can but its one hell of a thing to set up
Johnny Mac
stampman wrote:no you can but its one hell of a thing to set up
Is it the draw off the power and swr issues?
exactly
Johnny Mac
I've been looking at some of the specs on some of the high end yank export radios and some have amplifiers built into them, like Stryker and Magnum. Would these still cause problems using them on high power in a lorry? They look like they are designed for mobile use.
yes because of the power drain when useing power
Johnny Mac
Ok thanks Stampman.
Would 10w output be ok without all the power and swr problems?
yes you should get awaywith that but do DO DO make sure the swr is right
Johnny Mac
stampman wrote:yes you should get awaywith that but do DO DO make sure the swr is right
Thanks, yes I will. Am I right in thinking the swr will increase as the output power increases as its reflected power that causes the swr readings to increase? So a reading of 1.5 is about the max for adding output power of around 10w?
YES YOU SHOULD GET AWAY with 1.5 on the ref
Johnny Mac
stampman wrote:YES YOU SHOULD GET AWAY with 1.5 on the ref
Ok thanks for your help Stampman :D
