Hi Just installed my new TTi TCB550N into my MX5 and powered the unit via a Mini Blade fuse adapter in a nearby fuse box, (was directed to use this method from another MX5 user),. Connected the Antenna and turned the unit on and got very low Audio via internal speaker, I Turned the fuse round in the holder (Just in case) but still very low audio, Anyone else come across this problem?
Thanks Bill
very low Audio on TTi TCB550N
billybobbybutton
Update, Ran an a Power feed direct from the battery, made no difference, spoke to Thunderpole and the very kind Colin there talked me though some tests , it turns out there is a set fault, so just sorting out the RMA,
PolishNicholas
We have a TTi 771 and the audio is very good (in WV sharan).
