new comer, how does this sound ?
Andy_1984
ill be buying a new car (well used) in a few months which will be a ford mondeo. im thinking of buying the roadcom http://www.thunderpole.co.uk/team_roadcom-silver.htm for the realy long road trips up to fortwilliam and beyond to go fishing.
as ive seen on this forum an antenna is a big concern. im hoping to beable to replace the cars existing arial with a small and suitable antenna good enough for my chosen cb, are there adapters made for this so there is no additional wiring needed.
my main reason for choosing this is that it will fit the old radio bay which brings me to another concern, im a total newbie to cb radios but if i replaced the car stero with the cb can i still use the cb to pickup radio stations like clyde1 and so on.
also power for the chosen cb, is it fairly straight forward to hook it up to the alternator so its not taking directly from the car battery and use just like any other eletrical appliance on the car when ignition is on and not draining the life out of the battery when left alone ?
last thing, hooking the cb up to the cars integrated audio, how large a task would this be ? again are there adapters that can be used for the existing wiring loom for the car stero.
Regards
welcome to the forum andy
please keep us up to date on your progress as all what you are proposing
breaks new ground for cb all the adaptors you require have not been designed yet and the meathod of wireing the cb to nthe altinator sounds iffy and complecated keep it simple the cb will not recieve comercial radio stations unless you get a music player on the airways fit the best antenna you can afford as this does all the hard work for you fit the cb in the dust pocket if there is one and wire directly to the battery in other words keep it simple keep it easy cause sods law says the first thing to go wrong is the thing that took the longest to do ie:takeing panels off to hide wires behind will always cause the screw to cut the wire
Andy_1984
i think hooking it up to the alternator should be a simple task, just need to get somthing to regulate the voltage.
next step would be to figure out how to securly fit the antenna to the existing external car arial might just do it with a boot clip.
as for the cars own audio system im sure there are some converters for other such audio and visual entertainment systems about. what audio out options does my choice of cb have (i cant find the info im looking for)
finaly, my own music or radio like clyde1. im not a great radio fan what i would be looking into is my ipod, it has an accessory called an itrip that can broadcast the music on any given FM signal, might beable to work with the cb but im not sure.
ill keep a log off what i do and put it here for others to use if they like the idea of integrating all there audio and radio systems.
the speakers of a car radio system are the wrong value for cb radio's why make it hard work by tying the power into the altinator when you can go strigh to the battery cb's dont drain power when switched off and use a good cb antenna mounted on a boot mount if it fits
the only audio out on a cb is a 3.5 jack plug wired mono at the rear of the set
the i pod uses 88-91wfm frequancy range i think cb works on 26.965-27.99125 nfm and is therefore incompatable
Andy_1984
i hear what your saying about the battery and alternator, best way is realy to wire it up to the alternator as this gives everything its power when the engine is running, i dont want to have even the slightest drain from my battery that can be sorted by wiring to alternator, it isnt a tough job im used to getting under the hood, its just running the wires from one end to the other is the hardest part.
there are a number of converters for other in car entertainment systems like dvd players and even your playstation, is that 3.5 jack the same one an external speaker would fit in to there is most defenetly a way of riging it up might just take a lot of trial and error.
good luck and may the faireys of fortune fly with you
Sparky
I'm afraid I would agree with stampman, it would be better to wire it in the conventional manner ie supplied by the battery, a lot of alternators use a reverse flow of current from the battery to start generating (exciter voltage), I add that I am not an auto electrician so would advise you check with one before you proceed.
Sparky
I get confused if there is more than two wires
Basilsparents
Do NOT wire it to the alternator, an alternator is called and alternator because it alternates: it ouputs AC electricity! Although it varies from vehicle to vehicle, some convert it back to DC inside the alternator, whilst others do in a seperate part of the ignition circuit.
Risky business in my opinion
Take a spar off the cigarette lighter socket
welshbaycouple
Hi andy i came back on the cb a few months ago after trying several antennas magmounts and gutter mounts i fount the gutter mount to be best....i bought a thunderpole antenna called the red devil for 17 quid and its awsome mate i rate it as good as the k40 or wilson which can cost you upto 60 quid..i live in colwyn bay and talk to lancaster southport liverpool ect on fm and i have had malaga on sideband using the same antenna...i found that magmounts used to fly off when i got over 40mph but the gutter mount is fine at around 60mph ...i would advise wiring it to the car battery it doesnt drain the battery at all and gives you the best output/ good luck mate happy dxing
Andy_1984
cheers for that welsh, mondeos dont have gutters so probably boot mount.
as for alternator i wasnt saying directly to it but rather in the same way that other electrical equipment on a car can take from it other than the battery, but after speaking to a friend who does alot of car electrical work the electricity that comes from the alternator has far to much electrical noise that it would just interfere with the cb so battery it is then.
seen a friends mondeo today and it has an another identical hole in the dash under the radio (same dimensions) so no need to replace the car stereo.
noise from an altinator generaly comes via the antenna not down the feed wire
:D :D :D :D :D
