static problems
sparky1251
many yrs ago it was our cb's causing the problems.
now I'm hoping someone can help me out here.im running a anytone cb radio,sirio gainmaster.
I got it all set up,swr 1.2 across the bands perfect.
the problem I have is really spoiling how well I receive.my transmission is excellent.i was getting a constant +10 through every band.
I do have a cctv system which I was told could be the problem.i managed to cure this using two ferrite rings on the power supply to this device and it has stopped the interference.
I'm still getting 7 pounds of static sometimes 9lb constantely making anyone under this hard to hear and only local stations being clear.ive done what a few have said turned off the house supply and run my radio on a car battery to illuminate the problem but its still occurring,
ive took a ground from my power supply to radio no different.
would an earth from the radio or earth from ariel to a ground rod help?.
I have noticed when there is no antenna connected the signal is zero.
if I place a 6" piece of wire in the radio antenna socket,i get 30+ of hash/static.
I'm lost and really want to get back into my cb radio after a very long time out.what chatting I'm doing is within a mile radius at the moment.anything over this is a struggle.
really hope you guys have a solution.if I cant find a solution then I'm afraid I might aswell give up.
I'm not a quitter lol,i really have tried everything without success for this past two wks.only thing left to try is earthing to ground.
many thanks mark.
73's.
if the interference goes when the antenna is pulled then it is rf airborne and you have to find the source and stop it there
stewartyboy01824
I had this exact same problem when I had a base station a few years ago, I had a Harvard home base and silver rod right on top of the chimney, for years it worked brilliantly, spoke for miles! then all of a sudden one day I was receiving 5 pounds of static and never got rid of it! I put it down to an electricity transformer on a pole about 25 yards from the house. im sure it wasn't there before and when I noticed it looked a new piece of equipment so I'm now convinced it was that giving me constant interference.
so I would check outside your house if there's any substantial pieces of electrical equipment strapped to poles or pylons close to your house, failing that try a different position for your aerial its obviously picking up something it doesn't like. good luck! Stewart.
sparky1251
well ive tried a copper earth rod 4ft into the ground.brought an earth cable from the base of the antenna to pole and then to ground.unfortunately no different.
recentely purchased a grandstand Homebase,thought an older chasis may make a difference,as I have been told that anytones do bring a lot of rubbish.it had made a slight difference but not a grt deal.i borrowed a hand held and walked around my local area.i have a mini substation around 50yds from my home,and found a considerable difference when getting closer to it.
if it is this causing the problem,there isn't a grt deal I can do about it unfortunately.apart from relocation or getting the antenna higher,im shooting a dead duck.my antenna isnt at a grt height compared to what I'm used to.as mentioned I'm using a gain master,the base of which is only gutter height.maybe another 10ft higher may make a difference.something I will have to try when the weather is a little better.
thanks for the replys chaps,im at a rutt at the moment.
stewartyboy01824
I can almost guarantee it's the substation giving you the problem! Not sure what to suggest but good luck. Stewart
