Install Antrone 99
BrokenSticks
Hi all,
I am planing on putting an Antrone 99 on the side of the house. If anyone has info and links to the sort of fittings I will need to do this so its safe and very secure, that would be a great help :) also any tips if you have them.
Thx
very good antenna works very well. and they dont brake in bad winds *King*
T&K brackets about 3 feet apart with aq 6ft pole above the roof and you should be fine
BrokenSticks
as in the pole should be 6ft total? or 6ft above the roof?
thx
stampman wrote:T&K brackets about 3 feet apart with aq 6ft pole above the roof and you should be fine
above the roof mate 8)
matchbox
BrokenSticks wrote:Hi all,
Thx
Thunderpole sell em
