wattage
andy.73
is it possible for an everyday joe bloggs to uprate from 4watts? :?:
no needs to go on a meter and you dont get that mutch improvement in signal better to use a burner
andy.73
that will lead on to my next question...burners?? what and how!!
i work in the woods so having a very strong signal would be a huge benefit to me!!
first use the best antenna you can sirio 4000 or wilson 1000 the put an ea150
burner on wired direct to battery fix echo power mic with just a hint of echo and you should get out very well
andy.73
are burners fairly easy to wire in?
one of my pet hates are people with echo mics who have the echo set on!!
tried a thunderpole power mic today and that was working ok.
new wagon on monday...07 plate r series scania. never wired cb in one these, do they come pre wired?
cheers andy
fit antenna to gutter at rear and feed through grommet at rear of cab
drop lead through gap between roof and front cuboard fish lead out through glove box next to tacho there may be 12 volts up there the do vary think it depends on where they were built if not run volts from down on dash
andy.73
ever helpful my man!
just finished my job...had to strip old cbs out my MAN, left everything tidy!!
now got some cold bottles... :wink:
