Sih=gma 4 et al
Magic Roundabout
When I was a young breaker in the 70s and 80s we were not allowedc tuo use silver rods, sigmas, etc etc. How is the law now regarding these antennae? Also, if I git caught using a 100w boot would I still get nabbed?? Not that I would use one, of course :wink:
Hi there,
You are actually ok now to use 5/8 waves and 1/2 waves legally.
You might want to check with your local council about planning permission though. But as long as none of your neighbours complain you should be ok. :)
Yeah it is still illegal to use a burner #-o
hi there
local councils seem to ignore cb antenna as far as i cam remember anythig above chimney hight requires planning permisson this drag tv antennes into the equasion so as long as there is no interferance you should be ok also if you get it above the tv antenn you should have no televison interferance
plus if one of the neighbours starts hearing you when watching coronation street they no where to come instead of ringing busby
cheers and beers b
