Hi All
stardj
:D
Having a go or trying to get set up and into Cb again after year break. thought I d say hi. Still having the same problems now as when I was 15! can anyone advise? I still have problems fitting and slodering the PL pligs to the coax and always did. I got some new cable soldered the plugs on and cant hear anyone or tranmit! :cry:
I s there a wrong way of putting these on as its infuriating me.
Help
and Helloo
just check for short in plug end
:D :D :D :D
CrunchyNut
...and always get the wire AND the metal on the plug hot at the same time - then apply the solder.
Here's a link:
http://www.thunderpole.co.uk/forum/viewtopic.php?t=748
EarthWormJim
Hi welcome to the nut house mate. It took me a lot of practise soldering pl259s on to coax but got there in the end 8)
Jim,
2H4OW
M3OJP
stardj
Thanks a lot mate. I could never do it even when I was 15 and still cant now. I think Ive damaged the cb now though through messing with it and keying up , checking swr etc when soldering.. Do you know how I would tell if Ive damaged the transistors in rig?? I can hardly pick anyone up on radio and knowone is replying when I ask for rig check etc??
Regards
Paul
if you have a swr meter the the meter needle should swing when you press the mic to transmitt
EarthWormJim
Well im 21 now and I kind of started soldering and stuff when i was 15/16 and ive just about mastered the soldering a pl259 to the coax thing :lol:
same as what stampman said about the transmitting problem :?
Jim,
2H4OW
M3OJP
