Hi There.
I am going to purchase the Maycom EM 27 CB.
My idea is to use the EM27 at home, obviously they use car cigorette lighter power adapters.
What can I do to get power to the CB from my wall socket?
Please note, I am a learner to this.
Any help would be appreciated.
Thanks.
Stuart
Maycom EM 27 @ Home
Paul (2H3CK)
Hi Stu,
You'll need to pick up a power supply which i'm sure you can get from this site. The power supply converts the 230V mains AC voltage and transforms it down to 13.8V DC. For just a rig such as the Maycom a 3 Amp supply should suffice.
Hope this helps!
All the best....P
Hope this helps!
All the best....P
All the best.....73....P
- andy@thunderpole.co.uk
- Site Admin
Hi Stu,
The power supplies are on this page...
http://www.thunderpole.co.uk/power_supp ... andard.htm
The 2-3amp should suffice.
Regards,
Regards,
stu
Thanks Guys.
Just out of curiosity, if i wanted to buy a better rated PS,
Is it possible for me to go the extra and buy the Palstar PS-06?
Would it do any harm, E.g - supply too much power and blow the CB?
Regards,
Stuart
Regards,
Stuart
- Site Admin
No it should be fine. As long as the voltage is 13.8 Volts it will work.
There is just more current available for any connected equipment to use.
I hope this makes sense?!
stu
Yes, I understand that loud n clear m8.
Thanks.
What I'll do is get the M-490 Intek CB and the PS-06 Palstar.
The only one other thing I had in question was .....
Sorry to be a pain...
The Distance/Range I could get with the DISCOVERY III 1.75m Aerial?
Thanks.
Stuart
Thanks.
Thanks.
Stuart
- Site Admin
That is quite a difficult question because the answer depends on many things, local terrain, conditions and what vehicle it is mounted on.
As a rough guide though I would say up to 10 miles should be attainable in good conditions.
stu
Hi Andy.
Yea, I know what you mean.
I have read on the other threads, a couple of guys were using A99 type of aeriel, they were saying the were gettin a really good signal.
I was gonna invest in one of those.
I know this will be a silly question, but,
Is it possible to get an aeriel that will transmit around the world
Regards,
Stuart
Regards,
Stuart
