PMR Frequencies and CB
audiobull
Now I like the idea of chatting but no idea how it works.
In our off road buggys we have a cb system. I have a midland alan 42 ds also and a thunderpole 1300 (i think, the small slimline one)
anyway.
I have just purchased a few 3M Peltor litecom plus headsets which are PMR and something else because the buggys are so noisy I cannot hear the CBs even with bigger speakers etc.
Is it possible to pick up the CB frequencies or an I barking up the wrong tree because they are completely different systems altogether?
Paul 13
CB and PMR Radios work on completely different frequencies all together, CB's work on the 27Mhz and PMR works on the 446Mhz band. Answering your question they wouldn't work together as they are at complete opposite ends of the frequency spectrum.
Another thing to consider is the output of both devices run and work on different power outages so CB works on roughly 4 watts where as PMR runs off 5 milliwatts.
PMR radios also work over the shorter distances as well as line of sight so that's another thing to consider where as CB can go over longer distances too
Hope this helps you out
Hair Bear
There are or were, wired headsets for use in motorcycle helmets. There's a 3.5 jack for the speaker, and then it depends on what rig you have as to what mike plug you need.
