>>>Below are four (4) questions and a bonus question.
>>>You have to answer them instantly. You can't take your time, answer
all
>>>of them immediately.
>>>OK? Let's find out just how clever you really are....Ready? GO!!!
>>>First Question:
>>>You are participating in a race. You overtake the second person.
What
>>>position are you in? ist
>>>Answer:
>>>If you answered that you are first, then you are absolutely wrong!
If
>>>you overtake the second person and you take his place, you are
second!
>>>Try not to screw up next time. Now answer the second question, but
>>>don't take as much time as you took for the first question, OK?
>>>Second Question:
>>>If you overtake the last person, then you are...?
>>>Answer:
>>>If you answered that you are second to last, then you are wrong
again.
>>>Tell me, how can you overtake the LAST person? You're not very good
at
>>>this, are you?
>>>Third Question:
>>>Very tricky arithmetic! Note: This must be done in your head only.
Do
>>>NOT use paper and pencil or a calculator. Try it.
>>>Take 1000 and add 40 to it.
>>>Now add another 1000 .
>>>Now add 30
>>>Add another 1000 .
>>>Now add 20 .
>>>Now add 10.
>>>What is the total?
>>>Scroll down for answer.....
>>>Did you get 5000?
>>>The correct answer is actually 4100. If you don't believe it, check
it
>>>with a calculator! Today is definitely not your day, is it? Maybe
>>>you'll get the last question right... Maybe.
>>>Fourth Question:
>>>Mary's father has five daughters: 1. Nana, 2. Nene, 3. Nini, 4.
Nono.
>>>that is the name of the fifth daughter?
>>>Did you Answer Nunu? NO! Of course it isn't. Her name is Mary. Read
the
>>>question again!
how did you do
