two ariel set up
none att all in england as we have no stright roads the twins focus you signal in a figure 8 so itin stronger at the front and rear of the car ie following your headlight pattern and as we have no roads strighter than 440 yards you signal will be all over the place plus on a car you can not get the spacing between the antenna they must be over 1/4 wave length apart
see saved you money
see saved you money
