maybe the best antenna.
well with cbers look after each other as most of us did back in the 80s i have something to share with you all,
The Sirio Hypower 4000
A high quality 7/8 wave mobile antenna.
A larger version of the Hypower 3000, this one features a 2m long whip.
The coil is made from heavy duty plastic and contains a large cross-section copper coil. A swivel adjusment at the top of the coil allows the whip to be angled to suit the position it is mounted.
The whip is tapered and of high quality stainless steel.
Probably the best antenna available - it will certainly out perform a Wilson! :shock:
fits onto a large (7") matching Sirio mag mount (Mag-145). The mounting is an SO239 type - as used on Amateur antennas.
tends to break the internal coils if used mobile
fatfinger
Official CB Legend!!!
on another radio forum they did a test useing the wilson 1000 and the siro 4000
the wilson 1000 won
it gave a stronger signal
but there was not much in it
there both superb the wilson 1000 just edged it
the report is on this website somewhere as i posted it
jdo330
I would very much like to read that report as I would like to buy one or the other.
If anyone finds it can you put a link up as I cant find it?
ATB, Jon.
links to other forums not permited by the rules and regs but you can get him to pm the link to you
:D :D :D :D :D
jdo330
stampman wrote:links to other forums not permited by the rules and regs but you can get him to pm the link to you
:D :D :D :D :D
Beg your pardon, didnt read the post properly. I guess thats why I couldnt find it on here when I had a search #-o
ATB, Jon.
fatfinger
i will see if i can find it again and pm the link
fatfinger
i have sent you a pm link jdo330
check you inbox
jdo330
Thanks Fatfinger, very useful.
ATB, Jon.
hi guys when i go mobile i use a taped whip orbitor. but then i pull over and replace it with the sirio hi power and boy dose it kick out i just park up on high ground and never drive with it :shock: ::-()
