Afternoon Breakers,
Back on the cb after many years, and it's great to be back up and running again ( well nearly) Put my old barracuda in my 1972 bay camper, had it fitted with a gutter mount. It never had the greatest swr but nothing serious. I recently bought a new intek m550, great rig, had it set up indoors and have now decided to put it in my vw camper instead of the old one.
I put the new rig in and then went to try the SWR and it shot way off the red scale, i couldn't get it out of the red at all.I eventually gave up on the gutter mount and dug out the old mag mount. Being a 72 bay camper, the mag mount should act as a great ground plane, the SWR came down a little but still in the red, done all the usual things like checking cable and adjusting the aerial length but still no good.
The magmount is sat just over half way along the roof and the coax runs along the underside of the pop top BUT TOUCHING the metal roof, would this cause the massive reading on the SWR? The squlch sounds funny as well, not like a normal squelch should. I did manage to get out last night from Basingstoke and got out as far as Crowthorne / Berkshire.
Any ideas anyone? anyone close to Basingstoke who could have a look for me? ice cold beer in the fridge,
Hope someone can help
Buzz
HELP...SWR 72 vw camper van
GUTTERMOUNT at rear of front door dv27 antenna fitted swr will come down to 1.5 or less have fitted quite a few make sure you check the mount on the guttermount for a good clean connection and no short next check cable for short and water in cable if all ok then no reason why antenna will not swr
buzzbrittain
Hi Stampman,
Thanks for the reply. The gutter mount was set up just behind the cab door. I will dig it all out again tonight and triple check every thing again and have another bash.....fingers crossed x
dont forget to post some pics of the camper
im a big fan of old bays and split screen campers =D>
buzzbrittain
As soon as i get it all sorted, i will post some pics of the camper, she looks stunning, and even better with a rig in side (when it works)...lol
buzzbrittain
Still no joy, have tried a magmount ( on the back in the middle of the van) along with a gutter mount ( just behind the drivers door)and still in the red and all with different types of aerial. Would it be worth cutting the aerial down in size? im just wondering if the van is causing the problem due to its large metal body. Un-doing the screw only gives me a few mm's to play with, so would cutting the aerial down help the problem. Im pretty sure it's causing some sort of reflection problem
Many thanks for your help breakers.
buzzbrittain
HI mate, just tried that, so far i have taken about 8" off ( it is along whip though) and still no joy. Im keying the mike and the needle is hitting nearly 9, but the swr is way up in the red, i heard a guy talk who i have spoken to before ( with my indoor setup) and i called him and got no reply, so im not getting out at all.
HELP....
HELP....
