I think my Midland 98 plus is toast. I was out all day yesterday with some friends and I was having trouble breaking through their auto squelch but they could all hear each other fine. Did a few test and it would appear that unless I have perfect line of sight with another radio they cant hear me and range wise, I would estimate ive got 1/4 mile max in the open.
Anyway, when I got home I got the SWR meter out and tested everything. SWR was reading fine (1.2 on UK ch20 so happy with that - we were using 16 so I doubt this would have alterend much) but after a few goes on the SWR (you know, check & check again) it sprung up in the red so it would appear I have an intermitent SWR issue. Got a mag mount out and screwed in my antenna and it was fine over & over again so it would appear its the coax (must have crushed or pinched it somewhere?).
Anyway, as my radio now has super low power out, im assuming I must have trashed the output trasistors. Is this something I will be able to see inside the rig (ie, will there be a burnt thing in there)? I took the covers off both sides and everything looks fine, no obvious nasty bits.
Also, is there any way I can check the coax without removing it from the vehicle (its a pig of a job - headlining down etc)?
Thanks in advance...
ATB, Jon.
