Help
set = cb radio
swr = swr meter
VideoPirate
Thanks for clearing that up for me.
I think the radios are OK. The Commtron that I use is old but still works and the Midland Alan 121 is brand new, but then again it has not really been tested! (Got it for a good price)
When I get some time to re check the set up I willl let you know how I get on. I 'm determined to get this issue resolved.
Cheers dude have a good weekend
J
haveing gas and air at the barbers so could be better we will get the set up working eventually i feel sure
fatfinger
Official CB Legend!!!
gas and air where do you go sweeny todds
:lol: :shock:
VideoPirate
It's a Good stiff drink I need. Think one shall sneak off to the pub this afternoon before the ball & chain gets home from work. :D
fatfinger
nice 1
get me a jd in will you :lol:
you aint seen the mop
:D :D :D :D :D
VideoPirate
Dont have that Problem I shave mine right down to the wood. Not going bald but Much greyness. :oops:
If the weather holds out today(Looking very dull here) it's back to basics. First of all I'm going to unbolt the Silver rod from the shed and un-assemble all the parts. Then Will try adjusting the each segment up and down a little to see if I can get any better results. I'm also going to see if I can move the Rod to a slightly different location. I'm not sure, but where the rod is situated, it sits between(but slightly higher than) two wire's that are attached & coming from an old telephone Pole. I'm just wondering if that could becausing some form of interference?? As I say not sure but everything is worth a try. If I can get some time I try and post some Pic's of where the aerial is situated and the Telephone pole cables.
Maybe Just a stupid question. I presume wireless Routers do not interfere with CB radio? I know regulated wireless Routers & access points (802.11 standard)Most people who use routers in the Home either use 802.11b or slightly newer 802.11G the difference being the speed 11Mbs or 54Mbs. These Both run on a frequency of 2.4GHZ but I know can incur interference from microwave ovens, cordless phones, and other appliances using the same 2.4 GHz range. I know this a million miles away from 27Mhz but just a thought that the wireless router being in quite close proximity to the radios.
assemble rod to markins and slide bottom section in about 6 1/2 " and you should not be all that far out
We have a wireless router in one of the offices here next to the workshop. It doesnt cause any problems atall...
boyscout
andy@thunderpole.co.uk wrote:We have a wireless router in one of the offices here next to the workshop. It doesnt cause any problems atall...
Router wifi connection works at 2.4Ghz so it should be ok. :wink:
would be relay rare if the router caused problems
boyscout
Yeah and you would here the data traffic on the line, would sound like your old modem with the speaker on.
