Team roadcom - quiet?
Dave
Hi
A mate of mine has a silver/chrome roadcom and his modulation is very quiet... he has to shout into the mic about a centimeter from his mouth!
Is this usual on this model or is there something wrong?
Is there anything that can be done?
Thanks guys
Hi Dave,
This isnt normal on this radio. Has he tried a different mic?
It can be turned up inside if it does appear to be quiet.
IS THERE A MIC GAIN on it and if so has he got it turned all the way up
Basilsparents
Stampman goes straight for the jugular there :P
Dave
No mic gain on this rig.
Andy, is there a mic he could use that would give more power without him having to shout?
He likes the look of the Cobra M75 (another one of our drivers has one), i know this will need rewiring for the roadcom but would this work for him?
I think he's only just bought the rig - would opening it up to turn it up inside invalidate his guarantee?
Thanks!
yes it would invalidate his gureete easier to get the seller to turn it up then if its a deeper problem get them to change it as the set was faulty when supplied and adding a diferant mic will not sort the basic problem
I worked on a Team TS two way 4000 uk which had quiet and wooly audio ,i adjusted the board mike gain and even changed the tiny condenser eliment in these small horible mikes but no change to audio.
I believe this was a common fault on some of there early sets but but there recent sets generally have better quality controll so this shouldnt have be a problem .
A power mike may only make the problem worse.
My advice would be to take the set back and try another .
Regards Dragonfly .
