DISCO Owners
Posted: Mon Jan 07, 2008 7:28 pm
by The Straw Guy
Where do you mount your CB's?
I want to make mine look neat, not dangling off the transmission tunnel with wires everywhere. I have a sunroof unfortunately, so It can't go in the roof. Any ideas?
Posted: Tue Jan 08, 2008 9:57 am
without seeing the car its hard to say but you can always run wires under carpets etc
Posted: Fri Jan 11, 2008 6:51 pm
by Gav
Ive seen the actually rig mounted in the map pockets in the disco's..Aerial mount would be a gutter mount..
Cheers Gav
Posted: Fri Jan 11, 2008 7:05 pm
by Lamby
dont you still have that plastic thing in front of your sunroof?..My mate has a disco with a sunroof.His Cb is on the roof. I will look at it and inform you!
Posted: Fri Jan 11, 2008 7:23 pm
by The Straw Guy
I seem to be ruling out options pretty quickly
Can't go in the middle of the roof console because I have a sunroof
Can't go in the map pockets because all the PA rigs are too fat
Can't go in the centre console because it's not deep enough
Can't go on the rear of the centre console because it gets in the way of folding the seats forward
Posted: Fri Jan 11, 2008 7:38 pm
by Lamby
How about velcroed onto your speedo dash cover thing?...or would you not be able to see enough?.. :lol:
Posted: Sat Jan 12, 2008 7:00 pm
by mort
Well as a temporary measure I've got my rig jammed down between the drivers seat and the centre console.... :shock: But I have the same prob... I don't want it to be on permanent display but there is few decent (read non) locations for a normal sized unit...
So I'm with you on this one mate... :?
Re: DISCO Owners
Posted: Tue Jun 03, 2008 11:25 pm
by KAMASA
And I also wait with baited breath being a TD5 owner as well
Re: DISCO Owners
Posted: Wed Jun 04, 2008 8:44 am
under the seat with a channel change mic
Re: DISCO Owners
Posted: Thu Jun 05, 2008 8:44 pm
by randombod
like the idea of the chanel change mic, do you have stereo controls on your steering wheel if so what about moving the stereo to another location i.e under seat and putting cb in stereos place. OR my mate created a new centre box for his disco to hold a cb and vhf set up OR what about a remote head not sure if cb have these but vhf do so i woudl think so and put the remote head unit on the dash and the box of tricks in the boot.
just a thought or two #-o
Re: DISCO Owners
Posted: Tue Sep 21, 2010 8:09 pm
by LTH1965
Hi, I too have Sun Roofs on my Disco 1 but here is what I have done. My Rig is screwed into where the front Sunroof handle used to be. (I even used the same screw) Yes I took a screwdriver to the handle. One of the reasons I have done this is because my Sunroof used to leak but is now sealed. The only problem is the power cable runs down the front window but the coaxial runs above the sunvisor mount, comes out the side runs down the length of the vehicle at Grab handle hieght (Cable-tied to Grab Handles) then goes through/along the rear Alpine window surround, then pops out the back door to a gutter mount. I hope it all makes sense.......Lee
Re: DISCO Owners
Posted: Fri Jan 10, 2014 7:40 am
by AppleTree
Mine is jammed between the seat and the centre console, and wired into the rear cigarette lighter plug.
It works alright... I wanted it on the dash but tea leaves around my area now days... Grrr.....
Re: DISCO Owners
Posted: Wed Apr 26, 2017 9:35 pm
by blueovalcraig
I put mine in front of the sunroof buttons
Re: DISCO Owners
Posted: Fri Nov 30, 2018 7:13 pm
by AppleTree
blueovalcraig wrote: ↑Wed Apr 26, 2017 9:35 pm I put mine in front of the sunroof buttons
How did you secure it? I can't make it out?
Re: DISCO Owners
Posted: Mon Apr 08, 2019 7:04 pm
by blueovalcraig
AppleTree wrote: ↑Fri Nov 30, 2018 7:13 pm
I screwed the bracket into the plastic but I’ve now shifted it on top of my dash.
