DV antenna?
Posted: Thu Jan 31, 2008 4:41 pm
Hi all, first post so apologise if its in the wrong section, but its kind of antenna general so here goes....
I know about the 3/8 fitting arials etc... now, my truck comes with a "DV" fitting? which you screw what looks like a small screw into the hole.
Ive looked at different mountings and found a converter from DV to the 3/8 which i assume, i can then screw this little screw through the hole of the converter into the cab mount, and then have a normal arial on the cab.
But can you get DV arials? there must be some around if there are mounts for them? or am i stabbing wildly in the dark lol!?
Thanks for the help!
Speedy
Speedy
