Base antenna query
Posted: Thu Feb 28, 2008 4:27 pm
by magical mole
trying to find coax cuting guide for 91cm long satuan antenna with no swr ad ! if not wots best small base ant to go for must be cheapish! allso have 21 ft 5/8 silverrod wot to make wire radals 259cm to 264cm recmended is this right
Re: Base antenna query
Posted: Tue Mar 04, 2008 7:57 am
satuan antenna will not be altered by cutting coax and manufactured 5/8 depending on make do not come with ground planes but if you do it let us know the results
