SWR Antenna problems ~~ Help a newbie
Posted: Thu Mar 06, 2008 11:17 am
by dale9990
Hi There,
I'm very new to CB, just recently found a old mobile CB in my dads' loft. (Jesan KT-4004.) It all setup fine and i get a SWR of around 1.5 on low power (0.4 watt). But when i switch to high power (4 watt) the SWR stays far over in the red part of the meter. I have tried my mag mount antenna on my car and also in my house, but there doesnt seem to be any difference.
I know there might be lot of factors that contribute to this but can you tell it is my antenna or my radio?
Also is the radio i have a good quality, because i cannot find my infomation online.
Re: SWR Antenna problems ~~ Help a newbie
Posted: Thu Mar 06, 2008 11:35 am
check channel 1 and 40 if it is higher on channel 40 then shorten the antenna
if higher on 1 then lengthen the antenna
kt 4004 will work ok but nothing special
Posted: Thu Mar 06, 2008 12:07 pm
by dale9990
Cheers for reply
On full power the SWR is the same on channel 1 all the way to channel 40 (in the far red)
Any other ideas?
Posted: Thu Mar 06, 2008 3:10 pm
Posted: Thu Mar 06, 2008 3:32 pm
by dale9990
To be honest with you i dont have a clue, like i said im new to all this. Although i have included some pictures of the antenna if that helps.
Posted: Thu Mar 06, 2008 3:36 pm
yup splash out on a new antenna those are not the easiest in the world to swr std mag with dv 27 sorted
Posted: Thu Mar 06, 2008 3:48 pm
by dale9990
Thanks for the reply.
If i am needing a new antenna, can anyone suggest one for me to get (Homebase type). I'm not interested in anything special, so long as is works and gives a decent range.
p.s. Sorry, i do now know much about this subject. But hey we all have to start somewhere.
Posted: Thu Mar 06, 2008 4:25 pm
Posted: Thu Mar 06, 2008 4:39 pm
by dale9990
Ok Thanks for all the help.
Just need to convince the parents that it will look good on the house, lol
Posted: Thu Mar 06, 2008 8:16 pm
Posted: Thu Mar 06, 2008 8:27 pm
by jason
will put some pics of mine up after sunday,,
Posted: Fri Mar 07, 2008 6:13 pm
by compo
antron 99 with fire stick top section you will crack out with that on and to get the swr down if any problem aries put an earth cable on pole
