NEWBIE a little help
Posted: Mon Mar 17, 2008 12:05 am
by GaZz3
hi
im 15 and i was recently given a JESAN CB-950 well thats what it says on it as you may be able to tell i have no clue at all but id like to start using it can any one give me any tips on it how it works the range it would have i was told 3 miles im just looking for some pointers really.
Re: NEWBIE a little help
Posted: Mon Mar 17, 2008 10:05 am
Posted: Mon Mar 17, 2008 7:06 pm
by GaZz3
would it be useable as it is?
Posted: Mon Mar 17, 2008 7:15 pm
by jason
GaZz3 wrote:would it be useable as it is?
without antenna ????? NO NO NO ,
using without antenna will damage the cb,
Posted: Mon Mar 17, 2008 7:40 pm
by GaZz3
no its a sor of hand held one with a pull up ariel.
Posted: Mon Mar 17, 2008 8:06 pm
by fatfinger
you will be ok to use it with the built in antenna
Posted: Mon Mar 17, 2008 8:22 pm
by GaZz3
thanks all slowly working it out i think
Posted: Mon Mar 17, 2008 8:23 pm
by jason
phew,, i did not realise it was a handheld,,carry on,, enjoy,, 8)
Posted: Mon Mar 17, 2008 8:34 pm
by fatfinger
go on channel 19
and ask 1-9 for a roger
if someone says roger breaker back to you then people can hear you
if you would like to talk to someone
ask 1-9 for a copy
if someone wants a copy they will tell you which channel to use or you tell them which channel to go to
but you will get very limited range with a hand held don't expect big things
best thing would be to head to high ground so your signal gets out more
hope this helps
have a play and see what happens
Posted: Mon Mar 17, 2008 9:33 pm
by GaZz3
okay thanks i will try that i had been a little nervous to try saying anything lol.
what kind of range should i excpect with a hand held one?
also would it work in the car?
thanks for being so patient every one i have no clue at all.
Posted: Tue Mar 18, 2008 9:45 am
Posted: Sun Mar 23, 2008 6:08 pm
by plumb bob
I would think your range would be about a mile, maybe two on a good day, talking on the CB is no worse than putting your first post on a forum, nobody knows who you are, or where you are.
Avoid meeting anyone yet, unless with someone, same common sense as the internet really.
Enjoy.
