i just wondered , when i bought my antron a99 i was informed that the swr is factory set , so i just stuck it up in the air , i did check the swr and it was high ,, after a conversation with a few owners they said raise it as some of the antenna was close to the wall ,, i raised it as much as the pole would allow , this leaves about a foot of the A99 close to the wall of the house and the swr did go down further,,it reads between 1.5 and 2 on ref and i wondered if the factory set is the lowest reading you can get or would turning those rings bring the swr down, see i would like to get it down further without having to purchase a new pole or re drill my brackets if possible,,i am using 15 metres of rg58 coax
so,, do i turn those rings ???
do i ground it ???
tips on this please x x x
