Weak transmit signal
Posted: Fri Aug 29, 2008 8:36 pm
by hayabusaman0
Hi All, My set has worked perfectly for the last 2 yrs with a good range, however the other day I got in the truck & found that the ariel was missing, I replaced it with a new one & since then have only 4-5 bars signal strength on transmit( most of the time 0 bars and can't transmit) and a weak reception. I have swopped mikes for a known good one & fitted my old ariel but it's still the same, I have moved the ariel connector around while pressing the transmit button & that makes no difference either, anyone got an idea of my problem please?
P.S. I can be heard, but only when another radio is very closeby.
Cheers, Hayabusaman.
Re: Weak transmit signal
Posted: Sat Aug 30, 2008 11:08 am
Posted: Sat Aug 30, 2008 12:13 pm
by fatfinger
yes as stampman says swr is a must
sounds like you need to swr that antenna
Posted: Sun Aug 31, 2008 12:48 pm
by Nugsport
Did you by any chance key the mic on the radio without the antenna conected, before you noticed the antenna was missing.?
Posted: Sat Sep 06, 2008 5:59 pm
by fatfinger
good point could have blown the set
could try a dummy load
Posted: Sat Sep 06, 2008 6:06 pm
by Nugsport
Just what i was thinking matey the Output Transsistor could have gone. hopefully not for his sake. but you never know!
Posted: Sat Sep 06, 2008 8:51 pm
by porky.69
hi there is the coax damaged or been trapped in the door ...how old is radio and coax.it might just be what the guys say the outputs have gone
Posted: Sun Sep 07, 2008 8:14 am
Posted: Thu Jan 08, 2009 2:34 pm
by munky
I seem to be suffering a similar problem.
Just trying to get hold of a SWR meter tho, what should the reading be?
Posted: Thu Jan 08, 2009 4:07 pm
Posted: Wed Jan 14, 2009 4:36 pm
by munky
OK, so i've got myself a SWR meter, hooked it all up but the needle didnt move, not at all!
Is there anything I'm perhaps not doing?
Posted: Wed Jan 14, 2009 10:45 pm
Posted: Thu Jan 15, 2009 8:54 am
by munky
Ha! if only!
Its a brand new set!!!
I went out and got one last week!
Posted: Thu Jan 15, 2009 10:55 am
