Gutter Mounts
Posted: Tue Jan 20, 2009 1:16 pm
by andyd99
Is there a correct way of running the co-ax into the motor from the gutter mount without running it through open windows etc. Just wondering because ive got mine running through the door seals, wondered why yesterday and today i couldnt pick anytyhing up, and just found the coax has split because of shutting the door on it all the time. Would a mag mounted one be better suited, and if I got a mag mount, would it be ok for green laning, off roading etc going through narrow lanes and low trees etc???????????
Re: Gutter Mounts
Posted: Tue Jan 20, 2009 4:32 pm
Re: Gutter Mounts
Posted: Thu Jan 22, 2009 8:57 am
by andyd99
Silly question, and the reason why I ask is because the door seals are better on the passenger side rear door than on the drivers side. Does it make a difference which side the antenna is mounted on the vehicle, to the signal etc. As I say the door seal looks to be better on the passenger side than on the drivers side, so might not rip another co-ax if I put it that side.
Re: Gutter Mounts
Posted: Fri Jan 23, 2009 8:27 am
Re: Gutter Mounts
Posted: Fri Jan 23, 2009 1:25 pm
by andyd99
Re: Gutter Mounts
Posted: Fri Jan 23, 2009 8:02 pm
by hotmetal1000
yes
Re: Gutter Mounts
Posted: Sat Jan 24, 2009 6:31 pm
Re: Gutter Mounts
Posted: Sun Jan 25, 2009 10:17 pm
by porky.69
i used a dv27 on the gutter mount when i first got into cb.radio and it worked realy well very good antenna ...i dont know if they still do
make them i havent seen them around for a while
Re: Gutter Mounts
Posted: Mon Jan 26, 2009 8:30 am
Re: Gutter Mounts
Posted: Mon Jan 26, 2009 1:18 pm
by porky.69
hi stampman do they sell them at thunderpole and would they be ok for ssb
Re: Gutter Mounts
Posted: Mon Jan 26, 2009 1:45 pm
Re: Gutter Mounts
Posted: Tue Jan 27, 2009 12:43 pm
by randombod
i have a freelander and run it under the back part of the cab as it is detachable have you tried putting some tape around the part where it meets the door for a bit of extra protection. failing that the boot gaps can be a good place as they can be wider and cables dont always catch . then run th cable in the roof lining down the a post of the car (depending on where the rig is)
