Page 1 of 11
amature/cb radio set
Posted: Thu Jan 22, 2009 6:30 pm
by marsh phantom
hi all,
i after using a amature radio for my comms now,
so it must cover hf (obviously for 11m) i need 70mhz (rx mainly but tx is a bonus) 144mhz and 430mhz
the kind of radio i like is the yaesu ft857d but i cannot get a answer (not even from the tech guys at the shop) if it will give me 70mhz, now some sites say it does and others say it doesnt, i dont want to part with 5/6 hundred quid for it to miss out the 70mhz the bit i need second to 11m of course lol
now i am sure the icom ic 706mk11g will do it but i have been told that it is not as good as the yaesu so why would i pay 150 quid more without finding out the full facts on the yaesu first.
so does anybody have a radio that is like the yaesu that does the same kind of things that can give me a clue, or if you have this radio (modded or unmodded) what can you get
or recommend a radio that will do what i want. one more thing must be all mode (cw not needed but if its there i dont mind)
please feel free to pm me if you would like to remain annonamous
Re: amature/cb radio set
Posted: Thu Jan 22, 2009 8:03 pm
by hotmetal1000
Do you need 70mhz or do you mean 50mhz 6m?
I don't know if the Yaesu opens right up with mods a bit of googling and you should be able to find out, I do know the icom 706mkIIg will.
Posted: Thu Jan 22, 2009 8:30 pm
by marsh phantom
cheers,
yer 70mhz, its just out of its normal range.
have you used the icom? if so what are your views on it? do you haveexperiance with a modded tx range i.e 11m and what does the tx mod give you access to?
sorry i have questions for questions, just want to be sure before i spend the cash
Posted: Fri Jan 23, 2009 10:44 am
by hotmetal1000
the 706mkIIg is a good radio although they do run hot and I mean hot, doesn't seem to affect them though. Works well with the mars cap and allows you to tx across the rx range of the radio.
Posted: Fri Jan 23, 2009 10:56 am
by FISH
Why do you need to use the 4mtr band are you a ham guy.
Posted: Fri Jan 23, 2009 12:18 pm
by marsh phantom
thought i may get that question somewhere along the line.
work commitments (work radios are poo plus i can use 27mhz with the one set)
Posted: Fri Jan 23, 2009 2:41 pm
by FISH
Do you use 555 a lot bud.
Posted: Fri Jan 23, 2009 4:01 pm
by marsh phantom
i try to as much as i can mate depends on weather i can get up the hills or not in mid wales, due to my flat i cant put an antenna up so all my comms is mobile, when im at home in kent i have the rig running 24/7 as have the antron up on the roof.
what about yourself?
Posted: Fri Jan 23, 2009 5:35 pm
by FISH
Just getting back into radio on and off for the last 26 years.So just about ready to start running with a imax 2000,but i am on the look out for a beam for the flat side as it works much better on 555.radio and amp boxed ready to run.andy.
Posted: Fri Jan 23, 2009 6:29 pm
by marsh phantom
nice,
i will also be getting a beam soon i use a antron at home, a 5/8th silver rod for static/mobile dx on the hills was looking at the imax as the silver rod is not the strongest of things.
is the imax up? if it is how does it fair in the wind?
Posted: Fri Jan 23, 2009 10:50 pm
by FISH
not yet but i hope to very soon it seems the older you get its not so much a hurry in doing it, going to use the imax with a ts480sat so i hope the radio runs good with it.once it all gets set up i will post a pic of the set up bud.
Posted: Fri Jan 23, 2009 11:18 pm
by marsh phantom
nice one,
work has taken much of my time up now, its ironic i spend a lot of time on the hills with work then at the weekend i go back up there with the radio gear. all depends where i am in the counrty though.
will be mobile tommorow (sat 24th) from herefordshire to surrey, will be on the 19 all the way no doubt
Posted: Sat Jan 24, 2009 10:21 am
by FISH
what do you run with your vr-500 antenna wise.
Posted: Sat Jan 24, 2009 10:12 pm
by marsh phantom
mobile h/held either standard antenna or a watson w-801 regular gainer (to be honest they are both about the same rx wise, the standard yaesu antenna is not to bad)
mobile in car i use a dual coil mag mount cost 15 quid its 25-1300mhz with tx for 144/430 again works very nicely
home, a scan stick from maplins lol (not the best in the world) its cheap and short (about 1.5ish m) had to go for a vertical due to lack of space in my flat. againb this works ok,
there is not a great deal to listen to in hereford to be honest so i normally find my self on 70.6875 local fire brigade. if im up the hill all my antennas i use for the scanner are great (for obvious reasons lol)
Posted: Tue Feb 03, 2009 8:04 pm
by FISH
sorry i havnt got the shack set up so no pics just spent 8 days in hosptal.
