New mount and Antenna, & swr readings
andyd99
CB Handle: andyd99
Tonight, i have fitted a new antenna and gutter mount, as some little ******* decided to snap the old mount off, and trash my other antenna last week. I know whos done it, but cant prove it #-o
Any way, fitted a standard thunderpole gutter mount, with a thunderpole trucker 80 whip antenna to it (same as I had last time), and checked the swr. After checking the readings on ch 1, 19, 20, and 40, I found them all to have the same swr reading as each other, which is bang on 2. Is this normal for all to be the same, as i cant lower the antenna any more, its right down to the bottom.
Is this a safe reading to use ok???????????????????????????????
marsh phantom
CB Handle: Marsh Phantom
its usable with that swr although im a perfectionist and wont stop until my needle dont move on the swr meter lol
some of the guys might be able to suggest something else just to drop it down a bit more, is your reading of 2.0 using standard 4 watts output?
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
andyd99
CB Handle: andyd99
Yep, everything is completely standard, with all new coax, plugs, gutter mount and antenna. I dont know how to get it to drop down any lower, so any advice would be greatly appreciated. =D> =D> =D>
could be getting reflection from the roof which will make it highsee if there is a slight differance between 1 and 40 if its higher on 40 then cut about 1/4 of an inch and see what happens
