jumping swr
Posted: Wed Nov 22, 2006 10:09 pm
by zamo
i am having probs checking my swr.i have a moonracker mini mag and a pama gx25 and a ham international.i try and set the swr meter to SET but the needle jumps all the time.i get it as close as i can then it will jump back again.if i flick the switch it only moves just inside the red.i have tried 3 swr meters and 2 patch leads.it does it on both rigs.i only have one mic so if it is faulty could this cause my fault.i can rx ok.but no one replys when i tx.
Posted: Tue Nov 28, 2006 12:01 pm
make sure the ham is not on ssb as noise generates the power on this system other wise seems to be a tx fault in the set but would have to put on a test bench to prove
:D :D :D :D
