Page 1 of 2
dx weekend may
Posted: Wed May 20, 2009 4:28 pm
by porky.69
hi guys anyone going dxing over the weekend 23 24 25th may if the sun comes out then im going on my dx high spot in shrophire
so realy looking forward to it becos the skip is going realy well too :)
Re: dx weekend may
Posted: Wed May 20, 2009 4:31 pm
by oldskooldaze
Probably will try Sunday / Monday , managed to get 100km south of Berlin today not bad on a Wilson 1000 :D
Slowly getting there =D>
Re: dx weekend may
Posted: Wed May 20, 2009 6:56 pm
by marsh phantom
will be on no doubt
listen out for *King* 26-TM-1986 *King*
Re: dx weekend may
Posted: Wed May 20, 2009 9:42 pm
by Offplanet
Should be on UK40 on Saturday - generally listening on 19, but putting a few shouts out on Ch25 (good coverage of Wales from that QTH). On Sunday and Monday on SSB, and if Germany starts coming in like last Sunday, I'll give the EU block a try using FM.
If the skip really kicks-off, I'll put the 7ft Firestick on the van and head for a hill.
Cheers.
Gary
26-TM-2307
Re: dx weekend may
Posted: Fri May 22, 2009 5:10 pm
by porky.69
will be out and about sunday or monday ... *King*
Re: dx weekend may
Posted: Sat May 23, 2009 11:17 pm
by jonny66
ok who switched the skip of.
i heared a fella from italy this morning and then the furtest i reached was Harlow in essex.
better luck tomorrow :( :( :(
Re: dx weekend may
Posted: Sat May 23, 2009 11:23 pm
by marsh phantom
same here nothing today apart from the local guys
Re: dx weekend may
Posted: Sun May 24, 2009 4:50 pm
by porky.69
zzzzzzzz on the 555 usb only had a qso with my good friend bob tango mike 71 :D
no skip at all try on monday ... *King*
Re: dx weekend may
Posted: Sun May 24, 2009 7:17 pm
by jonny66
been listening to people talking to spain and italy but nobody could hear me :( :( :( :(
Re: dx weekend may
Posted: Sun May 24, 2009 7:42 pm
by Offplanet
Porky - another half a 'S' point and I'll be able to copy you no problem :wink:
What's giving you the QRM mate?
Good to catch TM 71 this time.
Gary
26-TM-2307
Re: dx weekend may
Posted: Sun May 24, 2009 10:08 pm
by porky.69
Offplanet wrote:Porky - another half a 'S' point and I'll be able to copy you no problem :wink:
Gary
26-TM-2307
oh gary im gutted ..i shouted you but the guy next door has a plasmar tv wich gives me 30 db of qrm ...im going out tomorow on 555 i hope to cach you
soon #-o
Re: dx weekend may
Posted: Sun May 24, 2009 10:37 pm
by marsh phantom
i also spoke to tm71 up in them clee hills (i went past there the other day), was using my spinger setup in the flat as im on duty so no hills for me
Re: dx weekend may
Posted: Sun May 24, 2009 10:54 pm
by Offplanet
Shame about the TV - I've had the same sort of problems and it's usually to do with the switched-mode power supplies in the modern kit.
Even this week I found my broadband router was giving S7 on some channels, and I cured this by using a universal regulated power supply from a local electronics shop instead of the one supplied with the unit.
I've got the QRM down on a lot of items using ferrites - the ring ones seem to work better than the clip on ones. I still get some with the DX setup in Bath, but no more than half a S point at the home QTH.
Hope the guy next door will let you try a few things!
I'm unlikely to be on SSB tomorrow, as I'll probably be at the Home QTH with only the UK40 at my disposal - there's always next time though.
I was putting a decent signal up to TM 71, but the trouble was that nobody else could hear each other :)
Cheers.
Re: dx weekend may
Posted: Sun May 24, 2009 11:01 pm
by marsh phantom
Cheers.
you signal is flying straight over my twig gary, hereford is in a slight bowl though so that dont help, i was even giving a cracking signal to tm71 today.
he even said he could fault the lincolns audio, its doing me proud i tell you
Re: dx weekend may
Posted: Sun May 24, 2009 11:19 pm
by Offplanet
Clee Hills do seem to be a particularly good spot.
Good to hear the Lincoln is doing the biz.
Tony TM-034 said my Stalker is bang-on frequency, so it looks like my pen marks around the dial are spot-on (who needs a frequency counter :) )
