Page 1 of 2
Re: Best CB Radio for Europe Trip?
Posted: Thu May 21, 2009 10:19 am
by sab
Another thing I just thought of. If I mount the unit in my dash then how am I going to get the wire of the mic to come to the front? I assume that you plug the microphone into the back of the unt?
Posted: Thu May 21, 2009 11:52 am
by sab
Hey Andy,
Would it be the same if I mounted a 150 or a m760? The listing says the 150 is 'ideal' for it? What makes it better?
Posted: Thu May 21, 2009 1:55 pm
by sab
sorry no i meant about mounting it in the din slot. Should be the same for both right? as they have the same dimensions?
Posted: Thu May 21, 2009 4:59 pm
Sorry the description is a bit misleading.
They would both be suitable as they both use the same chassis and are the same dimensions.
Posted: Thu May 21, 2009 5:26 pm
by sab
Ok a bit of a stupid question... if I were to get two smaller arials, would I get the same range (transmitting and receiving) as one very long one?
does anyone have any recommendations on arials that are a little aesthetically pleasing too?
Posted: Fri May 22, 2009 8:02 am
Posted: Fri May 22, 2009 9:36 am
by sab
Ok let me rephrase...
Can I get a small arial with the same performance as a longer one? Like maybe a coiley one or something?
I'm going to mount it on the boot... but am scared if it is too long... it may come off at 170mph...
Posted: Fri May 22, 2009 9:56 am
by sab
Ok this one don't look too bad:
http://www.thunderpole.co.uk/on-glass.htm
There must be a way of getting several of these and connecting them together to get a better range?
Posted: Fri May 22, 2009 2:03 pm
You will be lucky to get any more than about two miles out of that antenna.
You cannot connect more than 1 antenna to get a better range, unfortunately it doesnt work like that
The only way to get a good range (more than 5 miles) using CB is to use a decent size antenna...
Posted: Fri May 22, 2009 3:36 pm
by sab
Hey Andy,
Can you recommend a couple of decent looking antenna's so I can decide on my perfect setup. It can't be too tall due to the high speeds and aesthetic reasons...
Posted: Fri May 22, 2009 3:40 pm
Posted: Fri May 22, 2009 3:48 pm
by sab
Hey Stampman.. it says that is almost a metre high!! Thats too high man... way too high...
Any other suggestions? I think I'm just gonna go for the internal window antenna.. unless there are any discreet external ones. Trouble is, I know the internal window one will suck!
Need atleast 5 miles trans/recv range.
Posted: Fri May 22, 2009 4:10 pm
Posted: Fri May 22, 2009 5:07 pm
by porky.69
thunderpole atom small and very good on receve...
Posted: Fri May 22, 2009 7:07 pm
by sab
Porky, you mean this one?
http://www.thunderpole.co.uk/atom.htm
It's 1 metre high!
