Aerial for inside a flat?
Dave
Hi, i think i want a rig at home for a bit, but live on the third floor of a 5 storey block of flats...
I cant get anything on the roof, i MAY be able to get something on the wall outside a window, but it would have to be descreet.
Have seen a few but what do you suggest?
You have a electronic ground plane mirror mount - would this work on a small bracket on my window frame?
Dave
Round Baler
The boomerang twig sounds useful in your case.
I often thought about a wing morror mount attached onto my gutter in the house. Put 2 pits of metal on my gutter, earth them and then put on the wing mirrir mount as that is the highest point in my house.
Never tried it yet as I did not know if it would work or not!
- Gordon
Round Baler
Basilsparents
[url]http://www.thunderpole.co.uk/excalibur.htm[/url]
I have one of these crudely screwed to the wooden panelling outside my window... seems to work nice. Doesn't need grounding too, apparently. But may be a little too big for you? :? Just a thought
Last edited by Basilsparents on Sat May 13, 2006 11:41 am, edited 2 times in total.
Yeah I would suggest the Excalibur too, the Boomerang might be too long for indoor use at over 3 metres.
Also Basilsparents is right, it doesn't need a groundplane. But it does need a set length of cable for it to work correctly.
Round Baler
What sort of range and SWR do you get Basilparents with the Excalibur?
- Gordon
Round Baler
Basilsparents
I am not sure as #1: my base setup is currently broken (and I've only just realised, being a little lacking in common sense) and #2: the area I live in now is hilly and rotten for transmitting around. However, I used to hit my gran's house in nearby Porthleven with it quite cleanly, and that is situated about 4 or 5 miles away behind a rotten hill. Also, I belive mine is not set up correctly, so it would probably be a much idea to ask the administrator (Andy?) on the subject.
Also, what is the correct cable length for the Excalibur, Andy? I feel a weekend of adjustments coming on :P
*EDIT*
Mmm... it would appear I have a cable problem, time to get the ladder out x_x
The cable lengths are all on the Excalibur page... http://www.thunderpole.co.uk/excalibur.htm
It might be best to get an SWR on your antenna, you can see if the cable length is ok and whether there are any problems with the cable then.
Basilsparents
About 1.8. I really can't be bothered to get it down and fix it now... gah :P
