Anybody Used One Of These ?
Posted: Mon Jul 13, 2009 6:35 am
by TheJester
Anybody out there used one of these and if so, how have you connected your antenna, cabling etc...
Im thinking of getting one and running cable into car via rubber grommet that currently takes windscreen wiper cable....
Regards,
The Jester
Re: Anybody Used One Of These ?
Posted: Mon Jul 13, 2009 4:52 pm
Posted: Mon Jul 13, 2009 7:41 pm
by TheJester
Would I get a proper earth from just filing away the paint on the bracket where it attatches to the bolts ? Or would I need to run an earth to the car body etc. Also I am looking to fit a wilson 1000 to the bracket what connections would you suggest ?
Posted: Tue Jul 14, 2009 11:46 pm
by Offplanet
It's Ok for protecting the antenna in off-road situations and looks good, but the mount finishes half-way up the back window, so not too good for range and maybe the SWR will be a problem too.
If you can mount an antenna on the roof then do that, as it's the optimum location.
Gary
Posted: Thu Jul 23, 2009 4:19 pm
Posted: Thu Jul 23, 2009 5:38 pm
by killer cam
Posted: Mon Jul 27, 2009 1:35 pm
by porky.69
SEEN THESE
Posted: Mon Jul 27, 2009 5:43 pm
by killer cam
same here porky
Posted: Thu Jul 30, 2009 8:22 pm
by porky.69
yep seen them are they any good ??
