fed up and need help dv27
Posted: Sat Aug 22, 2009 3:40 pm
by padster
well i got my pl259 got a aparks to connect it a mate set my new dv 27 up on tin lid and cant get swr down i do not know what to do had my rig since last tues not used it yet #-o #-o #-o #-o #-o #-o #-o
Re: fed up and need help dv27
Posted: Sat Aug 22, 2009 4:42 pm
by disgwylfa
padster wrote:well i got my pl259 got a aparks to connect it a mate set my new dv 27 up on tin lid and cant get swr down i do not know what to do had my rig since last tues not used it yet #-o #-o #-o #-o #-o #-o #-o
Are you sure your SWR Meter isn't duff?
Steve ("Cherokee")
Posted: Sat Aug 22, 2009 4:45 pm
by mpcapri
Not sure what difference it would make but we always used the tin base and not the lid
Posted: Sat Aug 22, 2009 4:48 pm
by mpcapri
Also double check the pl295 connections, make sure the solder has not become loose (it happened to me once)
http://www.thunderpole.co.uk/forum/view ... f=18&t=748 connect a pl295 plug
Posted: Sat Aug 22, 2009 4:49 pm
by padster
Steve ("Cherokee")
i sussed it used base and put foil down on floor readings now channel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok and safe to transmit
Posted: Sat Aug 22, 2009 4:54 pm
by disgwylfa
padster wrote: i sussed it used base and put foil down on floor readings now channel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok and safe to transmit
I've replied to this same question on one of the other threads, but what the heck...
The 2.4 is a bit borderline. Generally it's considered that "anything under three" won't cook your Finals but as your SWR is higher on the top-end I would adjust that DV27 slightly. Lower the adjustable tip by about 2mm and check the SWR again. Then maybe lower it another 2mm. A DV27 really should get you under 2.0 on all 40 channels.
Steve ("Cherokee")
Posted: Sat Aug 22, 2009 5:00 pm
by padster
Steve ("Cherokee")
i got channel 1 1.6 cahannel 20 0.1and channel 40 1.7 is this ok
Posted: Sat Aug 22, 2009 9:41 pm
by killer cam
thats fine
