antron 99
Posted: Fri Aug 28, 2009 8:51 pm
now i got dv27 sorted in about a month i was thinking of uprating could i put this antron 99 in loft
CB Radio, Amateur and 2-Way Radio Forum
https://www.cbradio-forum.co.uk/
where is best place to site it matekiller cam wrote:yes but it would be better outside
cheers budkiller cam wrote:outside if posble as high as possible
yes outside is better much better theres no brickwork around it you need to mount it on a pole up high in the clouds lolpadster wrote:now i got dv27 sorted in about a month i was thinking of uprating could i put this antron 99 in loft![]()
Wow! Must be some loft you have there if it will take an eighteen foot vertical! My loft would barely take an orbitor or something.padster wrote: could i put this antron 99 in loft ?
disgwylfa wrote:Wow! Must be some loft you have there if it will take an eighteen foot vertical! My loft would barely take an orbitor or something.padster wrote: could i put this antron 99 in loft ?
Steve ("Cherokee")
i qill get one ordered outside lolporky.69 wrote:yes outside is better much better theres no brickwork around it you need to mount it on a pole up high in the clouds lolpadster wrote:now i got dv27 sorted in about a month i was thinking of uprating could i put this antron 99 in loft![]()
its huge believe me loldisgwylfa wrote:Wow! Must be some loft you have there if it will take an eighteen foot vertical! My loft would barely take an orbitor or something.padster wrote: could i put this antron 99 in loft ?
Steve ("Cherokee")
lolporky.69 wrote:it wont look as big in the sky
