expat in spain,having problems with new set up.
Posted: Sat Aug 28, 2010 5:30 am
by weeman
hello all
im a new owner
this is my problem.
i live in spain benidorm area and live in a apartment block with open balcony area.
i have a super santiago 600 antenna (5ft 6ins in full height)direct bolted to my metal balcony railings.
all connected to a brand new midlands 48 excel muti
the problem i have is i can only pick up few people every........48 hrs.
is this normal or is it cause its not connected up....which was connected up by a prof company.
or would the high hotels or bulidings be the problem?
many thanks to thoses who can offer some answers.
the weeman
Re: expat in spain,having problems with new set up.
Posted: Sat Aug 28, 2010 8:54 am
by jumpingmaster
wonder what country mode you have the midland cb radio set to and your listening on ...?
Posted: Sat Aug 28, 2010 10:37 am
good points need to know which band you are working on plus i have no experiance of the cb sean in spain
Posted: Sat Aug 28, 2010 2:56 pm
by weeman
so please tell me what i need to do to fix this problems?i was hoping to chat to uk people or uk truckers around europe?
Posted: Sat Aug 28, 2010 2:58 pm
by weeman
i use eu mode or uk mode.......if this helps.
Posted: Sun Aug 29, 2010 10:29 am
does spain not use am but you might get truckers think they use channel 30 ukfm in europe
Posted: Fri Sep 03, 2010 9:50 pm
by White Magic
Hi Weeman, I think the problem may be there is just no breakers close enough to you to pick up. If your rig is just AM/FM then I would have thought it doughtful you could pick up the UK ( with the exception to certain days if the sun spots are right, but that would only be on AM and you would probably spend your time just chasing channels and not being able to actually speak.) I would imagine if your antenna is on a balcony then you would only be able to get out properly on your side of the building, if there is a breaker, say, 5 miles away in the other direction you may not be able to receive him. I'm not that familiar with your antenna but I think bacony antennas normally have a range of up to 10 miles. Does the antenna have an unobstructed view of 360 degrees or is your building in the way. If the building is in the way then that would obstruct your signal.
Regards Tony
Posted: Sat Sep 11, 2010 1:30 am
by weeman
yes i am surrounded by high rise bulidings.i do think this is the problem...............but what would happen if i was top floor above all the other bulidings?then what could i pick up?
Posted: Sat Sep 11, 2010 9:37 am
probably a heck of a lot more as with cb the higher the antenna the better
Posted: Wed Sep 29, 2010 5:46 am
by 26-TM-037
Sound like you need to get an antenna up high in the clear ....something like a Silver 5/8 wave rod or a Sirio 827 (try and steer clear of the A99 and the hype that surrounds it)...will work wonders for you then ...also you really need a SSB radio to work on the skip or propagation to talk back to the UK ...It can be done on the UKFM and on the mids in either AM or FM...but SSB is the way to go....try looking on YouTube for videos type in 27.555 and you should get an idea of how Skip works and how operators work other stations....SSB is illegal to use in the UK on CB bands (not that it stops people).....BIG ANTENNAS AND UP HIGH is really the only way to go for 11m operations.....Good luck sorting out you station and may work you one day on the band...cheers Mark
