newbie saying hello and needs help
Posted: Mon Nov 01, 2010 8:34 pm
by grease monkey
hi all thought i would introduce my self and join this forum. i havent got a rig at the moment.
ive had lots it the past sold everything about 5 year ago when i got bored.
ive now got an itch to scratch again.
i have now bought the following.
-PO 980 Extension Speaker
08027 - SWR430 Meter + Free SWR Guide
12099 - Thunderpole Red Devil
17061 - Thunderpole 3m Patch Lead
16035WILSON - Wilson Beehive Mount
01M490 - Intek M490 Plus
a mini orbitor
and a standard orbitor
im having problems getting the swr lowered. i get the following readings
ch 1 its reading 10 in the red
ch 20 its reading 12 in the red
ch 40 its reading on set
i set the meter on ch 20 by flicking the switch to fwd turn knob till needle is on set then key off.
flicked the switch to ref to get the readings.
ive checked for a good earth and coax shorts using continuity test with a multimeter.
and cut a inch off the ant and tried shortening and lenthening using the grub screws.
all 3 antennas give in the red readings almost identical to each other. but the one im wanting to use and shortened is the mini orbitor. this is fixed to my van shown in the pic below.
any help appreciated
Re: newbie saying hello and needs help
Posted: Tue Nov 02, 2010 12:33 pm
try swopping the red beehive had the same problem hanged the mount and it was sorted
Posted: Tue Nov 02, 2010 12:43 pm
We've not had a problem with those Wilson mounts as far as I know, but it looks like you've done everything else right so it might be worth swapping over.
If you pop it back in the post to us we will get you a replacement sorted.
Posted: Tue Nov 02, 2010 6:30 pm
by grease monkey
andy@thunderpole.co.uk wrote:We've not had a problem with those Wilson mounts as far as I know, but it looks like you've done everything else right so it might be worth swapping over.
thanks ill do that could i also send the swr meter back so it can be checked. regards scott
Posted: Wed Nov 03, 2010 9:12 am
Yes you can do, the address is on the contact us page above...
Posted: Wed Nov 03, 2010 3:04 pm
by grease monkey
ive found out the problem it is the stud mount thats faulty. there no continuity between the 3/8 thread and the centre pin on the so239 socket. bad thing is ive ruined my mini orbitor by cutting a inch off it. i dont suppose i could have a replacement sent first ? so im not stuck with a 20mm hole in my roof.
EDIT: all sorted with a phone call. new one in the post :D
Posted: Wed Nov 03, 2010 5:12 pm
Sorry I didn't respond quick enough! Glad it's all sorted now... =D>
Posted: Fri Nov 05, 2010 4:32 pm
by grease monkey
i must say im impressed with thunderpoles service. i rang explaining the studmount problem at 4;10 pm and the replacement turned up the next day =D>
Posted: Sun Nov 07, 2010 8:25 am
glad your sorted now
